Old 09-11-2016, 10:32 AM
Jameseric Jameseric is offline
My 1250 is not ported so I am not familiar with the ported systems. I thought he could direct the return from the control valve to the tank and then send the tank output to the return port on his 1450. Oh well, It was just an idea.
Old 09-11-2016, 11:15 AM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
he could but then the tank would have to be completely full and pressurized in order to return the oil. It would do you no good.
107 with rear lift
1250 hyd lift. 682 diesel project
Original project
#2 and tiller
#2 trailer
59M sheader
home made boxblade
wideframe 54" snowplow
Old 09-11-2016, 12:08 PM
Ok, does that mean both hydro ports supply pressure to the lift circuit?
Old 09-11-2016, 01:07 PM
It doesn't work that way.
No it wouldn't. It would just have to be at the same level as the rear end, and have a tube between. Still not worth it.
No.....
One is pressure and one is return. Just like any hydraulic circuit is.
I thought you said you understand hydraulics.....???
Old 09-11-2016, 11:07 PM
Here is the reservoir that I referred to earlier. I do not know if it will work or not.
http://www.ebay.com/itm/Cub-Cadet-Narrow-Frame-Hydraulic-Lift-Pump-Parts-/252535587347?hash=item3acc4b4213:ggIAAOSwHoFXq7A n
