Old 10-05-2016, 02:00 PM
Originally Posted by john hall View Post
I think its time for you to stop painting and start fabing up a stretch frame Cadet!
I've you've got the money, I've got the time.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-05-2016, 02:07 PM
Someone already did.....
There's a video somewhere of him using it
Old 10-05-2016, 03:28 PM
That's cool but there doesn't appear to be alot of cub left, if I were to do it I'd want to be how Ford did it so it still looks like a cub.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-05-2016, 09:53 PM
john hall's Avatar
Well it appears this project has hit a roadblock already! Guess you are going to need a venture capitalist.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 10-10-2016, 08:51 PM
Merk Merk is offline
I finally found some pictures of my belly mount blade.
My blade has a side cover on it
There is a 3 inch gap between the ground and bottom of the blade when the blade is up.
I have used the blade for leveling my driveway.
Project Uncle Dick
Cub Cadet 70
Old 10-10-2016, 09:01 PM
john hall's Avatar
Merk, yours is pulling from the front end, I'm pretty certain mine is pushing--I think your setup may be better. Do you let yours float like a mower deck? I never could find that sweet spot of down pressure the way mine is rigged with the hydraulics.
2072 w/60" Haban
Old 10-10-2016, 09:32 PM
My blade floats like a mower deck.
My 100 has a manual lift. It looks like you could stand on this blade if you need more down pressure. To me a belly blade should be used for finish type work.
I found this blade at a garage sale. The gent that built the blade passed away a few years ago. It is a neat set up that could be used on a narrow or wide frame Cub Cadet. You just need to change the mule drive.
Project Uncle Dick
Cub Cadet 70
Old 10-10-2016, 09:44 PM
john hall's Avatar
Yeah, as discussed earlier, the Cadet (or any mower) is awfully lightweight and short in the wheelbase dept. compared to a road grader. I've never fooled with a blade of any type on anything other than farm tractors. Have you ever ran one on the rear of a mower to compare how it does to the belly mount setup? I wouldn't mind trying to get mine to float so I can use it for touchups after storms.
2072 w/60" Haban
Old 10-10-2016, 10:32 PM
I've ran front, mid and rear mount blades. The rear mount blade was an utility (IH 504) tractor that had a loader on it. The only way I would use the mid mount/belly blade is on the Cub Cadet with manual lift. I have better/faster/finer control that way.
My blade has the floating lift links from a mower frame assembly. I like to try a non floating strap/lift link. I think I will have better control.
I have better control of a mid mount blade over a rear mount blade.
I haven't ran the blade very much this year because of health issues. I always thought of a mid mount blade as a finish blade.
Project Uncle Dick
Cub Cadet 70
Old 10-10-2016, 11:01 PM
john hall's Avatar
I agree with that--seems the entire blade would have to float as opposed to just one side.
2072 w/60" Haban
