Old 11-22-2016, 10:44 AM
It calls for "737-3023 Grease, CV Polyrex" on the Cub parts site. That said I use Mobil 1 grease, same stuff I use for every other thing I have that needs grease. They have grease fittings on the shaft and I just hit it a couple times a year.
Old 11-28-2016, 11:41 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
I finely got the 1863 engine back together. Still need a gasket between the carb and air filter and I lost one of the screws that hold the wiring connector on but it's running. Somebody needs to take this mower apart and paint it.
Cannon
https://www.youtube.com/watch?v=LIpn...ature=youtu.be
Old 12-07-2016, 11:24 AM
Cannon51's Avatar
The gasket that goes between the carb and the air filter housing came yesterday. This morning I went out and started putting the air filter on it and promptly dropped one of the screws down into the shroud. I tried to find and fish it out but it was hopeless so I pulled the engine back out and removed the shroud. Seems like if there's a way to screw something up I can find it. If there's anything positive about this I'm getting faster at pulling the engine.
Cannon
Old 12-07-2016, 11:33 AM
Terry C's Avatar
Terry C Terry C is offline
Glad you got it running. I've dropped things and spent hours trying to get them out, most of the time I would have spent less time just biting the bullet and taking the path that I knew would get them out.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 12-07-2016, 11:47 AM
Your not the only one to do that, welcome to my world.
Old 12-07-2016, 01:06 PM
Dirty Steve's Avatar
Sucks when that happens. Nearing the end though!
Old 12-11-2016, 05:09 AM
Cannon51's Avatar
I got it all back together and moved out of the garage. When i moved it I found a spot of hydro fluid on the floor, looks it's coming from the left side axle housing. I need to find a thread on replacing the rear axle gaskets and seals to see whats involved but don't think I'll start that any time soon.
Thanks Guys, enjoy the holidays.
Cannon
Old 12-11-2016, 10:45 AM
Do you have the Cyclops service manual? If not PM me your e-mail address and I'll send it to you.
Old 12-11-2016, 01:48 PM
Cannon51's Avatar
I do have it, I believe you sent it to me a few years ago. Thanks Sam
Cannon
Old 12-11-2016, 02:06 PM
Good, changing the axle seals is not that big a deal. Holler if you have any questions.
