#21
I found a pic of the braces but it might be an old pic from Sam. So the sgt braces would go on first, then my 3 pt hitch mount. That would make the hitch mount stick out farther but that shouldn't be an issue. As long as the braces don't come up too far on the rear bolt of the tractor, I think I'll be ok so it doesn't interfere with the pto plate.
#22
If you take a tube that fits loosely inside of the fill tube and goes down at least a couple of inches into the trans housing, it keeps escaping air from burping oil out the top of the fill tube. (Works for me anyway)
#23
I know exactly how it fits and it will work with your hitch. BTDT. One set on a 2284 (CADPlans) and another on a 2182. Pics are of the 2182.
#24
#25
You can also unscrew the dip stick tube and use a long funnel or tube to go down into the top of the tranny to fill it. Very easy and fast if the fender pan is off.
#26
That's a good idea Sam, you could use a crows foot type stud remover to remove the fill tube with the fender pan still on. Sorry, I'm still a newbie with these, all I have had to do is change the trans oil so far.
#27
If you look at this pic, you can see a red line above the 3 pt hitch brackets. Does the brace go any higher than that red line? Because if it does, it would interfere with the rear pto black brackets. |
#28
![]() For the last freaking time, they will work. Been installed on lots and lots of machines. Sam designed the damn things. I think he would know.
#29
I am 100% positive that they fit with the complete Cat 0 OEM Cub rear PTO hitch. Here is another pic of Cad's 2284.
#30
Taylorjm, the rear pto only mounts to the rear cover and top of the rear housing. It will work. I have several of the rear braces on my machines with rear pto.
