Old 12-07-2016, 12:50 PM
Nightow1 Nightow1 is offline
Originally Posted by CNeubauer View Post
How do you have your hydraulics plumbed? I'm getting ready to add a second and third valve to my 2182 and was planning on having the second valve run to the front right couplers like from the factory and teeing the third valve to the front left and to a set of couplers at the back. The second set of couplers at the front would allow for running a V plow at some point.
Get with Rescue11 he is the mastermind behind the Hydraulics on her.
I'm sure he will be happy to help/gloat
Old 12-07-2016, 07:32 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Yea, hey, no problem. Btdt, its not difficult. Time consuming, yes if you wanted to look nice. But since your 2182 has stack valves, you will need to buy studs at the tune of about $20 per and o-rings so that you can pack all the valves together. Do not over tighten your stack valves or they will not move very well.
The rest is plumbing, which is in my bag of tricks as an occupation. That 782 has around 90 feet of steel hydraulic tubing all hand cut flared and bent with over 40 individual joints. Probably best you peruse this thread http://onlycubcadets.net/forum/showt...t=31710&page=8
1- 1200 in pieces
1- 1864 in pieces
