Old 03-05-2017, 02:37 PM
mortten mortten is offline
IHCCW has two nuts. Part number KH-220786. They also have a picture of the line itself but don't have any.
http://ihccw.com/carb.html
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 03-05-2017, 03:00 PM
Originally Posted by ambrola View Post
This is just too complicated. I WILL find a used one. If not, I will put rubber on it and be done with it.
Come on Ronnie, don't be fuel-ish, you want it to be correct, besides that will be a sharp bend for a rubber hose.
Up to 534 and counting...
Old 03-05-2017, 07:22 PM
ambrola's Avatar
ambrola ambrola is offline
I don't give up that easy. If I must, I will take one of mine and have a couple stainless ones made.
Old 03-11-2017, 01:15 PM
ambrola's Avatar
I found these at a hardware near me. They fit in the carb. and sediment bowl. Any reason they wouldn't work with the compression nuts?
Old 03-11-2017, 02:06 PM
Those appear to be made for a copper style ferrule. No, they will not work with the rubber style ferrule.
Old 03-11-2017, 02:26 PM
Looks just like the one that was on my 104.
Old 03-11-2017, 02:46 PM
ambrola's Avatar
What will work? These? They look the same?
http://www.ebay.com/itm/151021302154...%3AMEBIDX%3AIT
Old 03-11-2017, 03:40 PM
Jon
Are you sure about that? They look like what was on my O.
Old 03-11-2017, 03:51 PM
Yes, I'm pretty sure. Hardware stores don't sell the type for rubber seal. The threads are different at the nut. It's a fine thread on the rubber type, and the flange is different. With a nut on and screwed down tight, they look identical, but they are different thread.
Now, would they seal..... Maybe since it's just gravity fed. But I'd lay a dollar down and say the nut already on the line is fine thread.
Old 03-11-2017, 04:00 PM
The ones you gots at the hawdware store are the same.
