Old 03-28-2017, 05:03 PM
brewsky brewsky is offline
Originally Posted by OldSkull View Post
Sound funny like a "Live" show but he already mention been a first timer Kohler "engineer" so why we don't give him a brake Mr Johnny gun?
Joke aside I enjoy the drama and wait for more action!
I have applied my "engineer" training and determined the PO is to blame, according to my problem solving class handout:
Old 03-30-2017, 08:02 AM
Set screws soaking in PB blaster...not real optimistic about them coming out without a fight though.
Meanwhile, trying to figure out if I can save the existing button.
There is a ridge built up on the thrust button where a groove for the snap ring used to be.
Options:
1: Start the engine and use it as a lathe and try to re-tool the groove with a small file. (engine probably shakes too much while running?)
2: Use a dremel wheel and try to re-grind the groove with engine not running
(I probably shake too much for this option!
3: Eliminate the brake shoe and plate, and use a homemade wear button on the actuator arm instead
Old 03-30-2017, 12:19 PM
Options:
Why don't you just buy a new one......
$10.50 each
http://ihccw.com/pto.html
Old 03-30-2017, 01:37 PM
OldSkull's Avatar
OldSkull OldSkull is offline
$10.50 each
It's not his fault, his problems solving flow chart is not updated, here the missing part...
Gilles.
1963 100 (red)/in storage
Old 03-30-2017, 01:41 PM
Old 03-30-2017, 02:29 PM
x.bhamcb x.bhamcb is offline
He said "engineer", but that looks more like the chart the production workers use.
Old 03-30-2017, 06:04 PM
$10.50 each
Cause I'm hearing the voices of 6 rusty set screws calling "just try me" from their deep dark dirty holes!
If they come out, I probably will.....thanks for the link!
Old 04-06-2017, 09:06 AM
Success!.....well, mostly...there were only 5 in there but they put up quite a fight...had to break out the valve grinding compound after soaking, heating, chasing threads, and tapping
The last one made it almost all the way out and then.......snapped in two!....might have tapped that one a little too hard?
Wonder if I can re-use this disc?
Old 05-15-2017, 08:37 AM
Decided to ditch the PTO brake and revert to a button actuator instead.
My machinist uncle had some spare bronze so I drilled and tapped a piece to use as the button.
New clutch disc, new set screws, new bearing and all is good!
Engine was fine all along...cut my first yard yesterday and seems to be working well.
Old 05-17-2017, 10:50 AM
and that as they say was problem solving.....good for you.... congratulations, youre NOT one of the 5 million "Americans" who can no longer do that sort of thing!!
was a good read though...welcome
