Old 04-04-2017, 11:15 PM
sorner's Avatar
sorner sorner is offline
Well I went for it and got it totally torn down to the block. The cylinder bores look good, there's even still some crosshatch in there and they feel good. No lips or anything. There is a little bit of wiggle to the pistons in the bore when I push hard on the sides. Is that normal? Everything else looks good.
Old 04-05-2017, 11:59 AM
RLause's Avatar
RLause RLause is offline
Do you know how many hours are on the engine?
Richard
Old 04-05-2017, 02:02 PM
sorner's Avatar
Hour meter has just over 1000 hours. I'm not the original owner so I don't know if it's the original motor or the history of it.
Old 04-05-2017, 08:04 PM
sorner's Avatar
I'm reading up on this. It's very slight movement, and I think this is normal. I don't have anything to measure bore size or anything.
Old 04-05-2017, 09:56 PM
RLause's Avatar
I was just wondering how long the cross hatch lasts on the cylinder walls.
Richard
Old 04-05-2017, 10:55 PM
PaulS's Avatar
PaulS PaulS is offline
Richard I have a ch20 apart that has about 1500 hrs on it and can see just a little crosshatch on the walls so they can last a long time.
Old 04-06-2017, 05:03 AM
sorner's Avatar
I read somewhere that the cylinders are so hard that most of the time a rebuild is just pistons and rings because they wear out before the cylinder wall.
Old 04-08-2017, 07:28 PM
sorner's Avatar
I made some progress today on degreasing this thing. I got most of the loose stuff off and now it's cleaned down to the baked on stuff. I guess I'll have to hit it with a toothbrush to make it sparkle.
Old 04-08-2017, 08:11 PM
Looks good to me.
Old 04-09-2017, 06:33 AM
bugeye bugeye is offline
Consider pulling the starter apart to clean, check and lube. Check brushes.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
