Old 05-04-2017, 08:01 PM
sorner's Avatar
sorner sorner is offline
What if you fart while you're using it? Does it throw off the reading?
Depends on the fart I guess.
Old 05-17-2017, 06:41 PM
Got my tach the other day and finally had time to check the 1211, it was only spinning at 3,420 rpm but it's now set to 3,650. The grass will need cut again in a few days and I will get to see how much it helps. If I have time this weekend I will check the rpm on the 100 to see how close Jon was on his guess.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-17-2017, 06:57 PM
Set it to 3800 Tim. They do much better there, and it's perfectly safe. I set all mine at 3800.
Old 05-17-2017, 07:01 PM
I hear you but this thing already sounds​ like it could fly to the moon at 3650, I will see how it does and go from there.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-17-2017, 08:58 PM
It's just because your not used to it running that fast. Don't be scared.
Patiently awaiting if I was right on the 100.......
Old 05-21-2017, 02:57 PM
I reset the rpm to 3750 no load which give me 3600 when the decks on, I mowed with it yesterday and it never bogged down even in the deeper wet grass in the corner of the yard. Very happy now.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-21-2017, 04:09 PM
