#21
If/when you get the plow set up correctly, the more power you have, the faster you can go. For me, though, it is not a race...... you want to go at a pace where the ground will lay over nicely....too slow and you won't get a clean furrow to travel through on the next pass; too fast .... well, to me it's obvious when you hit that sweet spot of a well-adjusted plow and a good-running tractor where it's not getting beat to death. I have seen some guys that might get a good setup on their plow, but then they want to go so fast that they almost throw the dirt onto the top of a previous furrow..... looked like a bass boat going through the water with a rooster-tail wake! I am going to add a link to an owner's manual for a Brinly sleeve hitch plow. It has some good setup instructions and diagrams. http://www.brinly.com/graphics/manuals/PP_51BH.pdf Even a well-adjusted plow will work better if it is clean. When you get finished plowing and want to store the plow, it needs to be washed off, dried, and coated with something to keep it from rusting. I use bearing grease and smear a light coat over the face of the plow. A little wipe before the next use will do, and it won't take many feet of plowing for that mirror finish to be seen again. Hope all this helps explain it a little better. Plowing is my favorite part of gardening!...... well..... until it's time to eat the results of the garden....... in between is a LOT of work!
nra1ifer ![]() Cub Cadet 123, Wheel Horse C160, Craftsman PGT9000, Speedex 1631 |
#22
982 with 3 PH, rear pto, front & rear hydrs & ps, 1772 w/3 point, rear PTO, 86, 2 Haban 60" decks, Haban 54" snow/dirt blade, Brinly Cat 0 Disk, 5' blade & 2 Cat 0 Plows, SpeeCo Cat 0 plow, Sears cat 0 Cultivator, Cat 0 CC 442 Tiller, 60” rear mower, 450 blower |
#23
I went back and edited/added a couple of things....
And, if you are using a three-point hitch, the goal is still the same: a plow that is going through the dirt at the right depth and with as little up/down and side-to-side friction as possible. On your bigger "real" tractors, power can overcome a plow that is not set as well as it could be. Doesn't take too long to eat up a lot of extra fuel, though.
#24
Well.... I don't know if they can necessarily plow deeper.... but the 4XX Deere's do have a 2 speed gearbox with their hydrostat which gives them much better torque. Plus, a 4XX Deere is heavier, and has a higher trans housing, so it has better clearance, and they have a wider stance, so you get better traction. Get those wheels where they need to be. I love my Cadets, but those green machines are a little better built.... Lets give credit where it's due. The 4XX Deere's are great small tractors. |
#25
Darrell my plows are off the tractors and all packed away until next year. I can tell you the way I set them up was following the manual for the brinly plow and they work great.
Charles________________________ 1572 3pnt, rear PTO, 50" deck 1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow 1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow 2072 3pnt 50" deck, Brinly Plow 2072 50" deck Cub Cadet Tank 50 Zero Turn Cub Cadet 33" Commercial Walk Behind 1953 Ih Cub with just about every implement New Holland TC33D with Loader and Backhoe |
#26
Most guys by me that have one treat it like a show car, just show it off and not do anything with it.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
#27
Gear box between the hydro and the differential. Where a CC's reduction drive is. The Deere's high gear is basically the same as a CC. Then it has a low range. Huge advantage.
#28
one of my brothers has a JD 455 (his is diesel, are they all?). It is a very nice tractor and I would love to have one like it.
#29
All 455's are diesel. 445's were gas.
