#21
But he said in post #1 it had good spark...... ![]() Nothing like giving accurate information. |
#22
First thing if it has good spark as you say and will not fire on starting fluid does it have compression? Check for a exhaust valve stuck open, a blown head gasket or a hole in the piston. Years ago my first Cub Cadet, a 70 with the K161 died and would not start and when I checked compression and had none I pulled the head. The top of the piston had separated and was stuck up against the head. It never made a sound just died when I was mowing. Let us know what you find
Tom |
#23
The engine threw a rod & of course has no compression. Will the 8hp kohler engine match up with everything? If so I may try to find one that's running. Thanks. |
#24
Good grief.
#25
I guess from now on we need to start the diagnostic process with checking for compression.
#26
you should have been at the auction I went to yesterday... lots of NOS Kohler Briggs and even Tecumseh goodies.... could have gotten what you need for that engine pretty cheap as compared to FeeBay.
#27
my mechanic is trying to locate me a replacement engine I Refuse to buy any "New Junk"
#28
Why doesn't your "mechanic" just rebuild the old motor?
#29
yeah how bout it?
There were no Kohler engines at the sale, but tons of parts that would have made the rebuild real easy.... |
#30
I guess to save time & money IDK.
