#21
That was the premise of me putting in a vent. I don't see how it couldn't be vented. I looked all over but didn't find one. Is there a small brass one or something that is possibly clogged and that is why I haven't seen it?
#22
The fill tube is the vent. Cap on the dipstick is vented.
#23
must not be venting then.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
#24
Possible, but not likely..... but he added another vent, so it better be.
If nothing else it will be easier to fill. |
#25
I think what you meant to say is. Yes, you are correct, it is splashed lubricated and the pump does not pressurize the case. But if the dipstick vent it plugged, it can build up pressure from the oil and metal expanding.
#26
No, I meant exactly what I typed. The expanding air is what causes the pressure. Even if the trans was pressure lubricated with a pump, that wouldn't cause the case to be pressurized.
#27
And that answer was much better than the condescending one you used the first time.
#28
Maybe you're just oversensitive. My first answer looks fine to me.
