Old 08-27-2017, 11:35 PM
Red rear axle: cast iron, built by IH
Black rear axle: aluminum built by MTD
With the exception of the serial tag, and lack of emblems, your 682 is an IH machine.
My 782 is according to the serial tag a later 1981. Can't remember the month, but it's a black rear, cast center with aluminum axle carriers.
Would be a CCC/MTD.
Old 08-28-2017, 01:02 AM
Would be a CCC/MTD.
As of yet, I haven't seen any of the '82 series with a black CI rear unless they were repainted. Not saying it isn't possible.... but not likely. I believe IH went to aluminum axle tubes in the QL series. I'd have to check some of mine, or the part numbers to verify. All the '82 series that had the aluminum axle tubes IIRC. They aluminum rear case trannies had a different rear cover, and were made different than the old CI unit's. They are easy to spot.
Old 08-28-2017, 07:05 PM
SS5150's Avatar
SS5150 SS5150 is offline
I have an mtd 782 with a black cast diff. Y/W serial 706125. I know 706124 was sold earlier this spring and had the same build configuration & paint, I considered buying it but ended up passing on it, holding out for a 582.
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 08-29-2017, 09:41 AM
bfowler88's Avatar
bfowler88 bfowler88 is offline
Anyone have any experience with a 16hp briggs and Stratton engine out of a YT-16 snapper. A member on here has one seems like it could work. Trying to dig up some info on it now. Let me know what you all think.
1971 IHC Cub cadet 106
1982 IHC Cub Cadet 682 (looking for engine)
Old 08-29-2017, 09:55 AM
sorner's Avatar
sorner sorner is offline
Don't hold me to this, because I'm no expert... but I think the 582 uses that style Briggs engine. Those mufflers aren't going to work though. You may need to change some wiring to do the swap, and at least need a muffler from a 582 with this briggs engine, and heat shields. Probably will have drive shaft length issues too.
http://www.tractordata.com/lawn-trac...cadet-580.html
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 08-29-2017, 12:32 PM
bfowler88's Avatar
The crankshaft diameter is 1" and I believe the original KT17 is 1 1/8" .
Old 08-29-2017, 12:36 PM
sorner's Avatar
That too. But that's easy to work around compared to everything else. You could replace the clutch or get a sleeve to make it 1 1/8".
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 08-29-2017, 09:03 PM
bfowler88's Avatar
Thanks for the info sorner .Im not sure this 682 has ever been disassembled and cleaned before, its filthy. Im sure you all have seen much worse though.
Old 08-29-2017, 09:06 PM
bfowler88's Avatar
Ive already done major cleaning forward of hydro .....
sorner's Avatar
I've seen 5, none of them have been clean. They all look like that or worse.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
