#21
Open, not close. When they open, ignition spark occurs.
#22
Points start to open - no mark in window - no piston movement Points open - still no mark - piston coming up Points open - still no mark - piston at TDC Points start to close - still no mark - piston on the way down Points closed - S appears - piston on the way down Points closed - T appears - piston on the way down After this the engine turns for quite awhile with seemingly nothing happening (at least visibly) |
#23
See my above posts.... don't want you to overlook them with all the "action" in this thread.
#24
I know the difference. PTO is in the front. Flywheel has the S and T marks on it. I don't have the PTO engaged right now and so it's not even moving.
#25
That would explain alot. I think it's time for me to stop monopolizing the forum and simply have my brother look at this thing and get it working again. I could go around and around here for the next year and probably be no farther along UNLESS it turns out to be the timing. I'll ignore the exhaust valve. Curious though...why would the exhaust valve be directly below the plug? When the plug fires...how does it ignite the fuel/air mixture? |
#26
Sorry, I got my mords wixed.
#27
IF, however, I put the flywheel on at the wrong place (is that even possible to do?), then of course the S and T marks would not correspond to when the points open.
That's why I asked if the key stayed in place when you reinstalled the flywheel.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
#28
As long as a spark plug is in the combustion chamber, location only matters to get the best possible combustion. Early K series the plug was between the intake and exhaust valves. It was moved to the front over the exhaust valve, we believe, to get a better, or more clean burn. It seems to be a better location, as the guys who pull or "ramp up" the power of the motor say that head can make a bit more power. I agree.... probably time to just get it over to your bro.
#29
He didn't take the flywheel off. He was talking about the basket pulley. He's never had the engine out of the tractor.
#30
