Old 12-02-2017, 09:46 PM
Before you go making spacers, you need to check to make sure the engine has all 4 spacers under it. Perhaps the rear ones are missing.
#2 in the pic:
The QA42A will go on an 1811 with no issues. No spacer washers needed. Your engine has to not be mounted correctly, or the pulley is wrong. You did change the pulley, correct? The one that it uses for the 1250 will not work with the necessary 5/8" belt the 1811 uses.
I've ran a QA42A on my 1811 one year when the 450 broke and I was waiting for parts. Mounted right up, no issues.
https://www.youtube.com/watch?v=gqK5r10xKBc&t=75s
Old 12-02-2017, 10:08 PM
Vrobert's Avatar
Vrobert Vrobert is offline
J-Mech, good catch and thanks for the good advice. I will check for engine spacers tomorrow. The PO had put a 5/8 pulley on the thrower already.
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 12-02-2017, 10:25 PM
While I'm noticing things.....
When you repaired your front axle, you put the bolt in backwards that prevents the axle from rocking. The bolt head is supposed to face the axle and it should have a thin walled jam nut on front to lock it in place. Wears better when it is installed correctly.
Old 12-03-2017, 12:27 AM
Vrobert's Avatar
I just replaced the worn castle nut and bolt with a longer bolt and used two nuts to lock it. Are you saying the frame or axle are supposed to be threaded? If so the threads are worn away. The bolt slipped right through them both. The frame is a C-channel so I tightened the first nut until the axle didn't wobble but was free to pivot, then jambed it with the second nut.
QA42 snow thrower
38" deck
44c mowing deck
QA42A snow thrower
42" snow blade
Old 12-03-2017, 12:33 AM
That's my mistake. The bolt I circled I now see is the center pivot bolt. It is installed correctly.
However, upon closer inspection, on the far end I can see the bolt I was thinking of. It appears pretty loose. (It's under the red circle at the 9 o'clock position.) There are two bolts that go through a "flap" (for lack of a better term) in the frame just in front of the axle. One on each side. Tightening them towards the axle takes the side to side play out of the axle. They are supposed to lightly rub the axle. Make sure they are adjusted correctly, and all is good. I keep a little bit of oil or grease on the head of mine when I grease the tractor. Keeps it from wearing the axle and bolt out. Plus, sometimes they squeak and it gets annoying.
That axle was worn pretty bad. Probably needed a bushing installed.....
Old 12-06-2017, 11:09 PM
Vrobert's Avatar
You will need to change three things to make it work.
* New PTO Belt - IH-78056-C1
* New Upper Mounting Links
* New Drive Pulley
Rats! I googled the part number shown of the angled bracket (IH 79011 C1) and I ordered this: https://www.ihccw.com/index.php?rout...earch=top+link
I received straight links because I didn't read all the way to the bottom of the description. I asked them to remedy this for me. I should have bought from Extreme.
QA42 snow thrower
38" deck
44c mowing deck
QA42A snow thrower
42" snow blade
Old 12-07-2017, 06:40 AM
"TOP LINKS ARE STRAIGHT (Not As Shown) "
Piss poor advertising. A responsible Vendor would have shown the actual part instead of mis-leading their customers.
Old 12-08-2017, 01:46 AM
Vrobert's Avatar
After emailing ihccw and complaining about the misleading listing for top links they refunded the money for the links and apologized.
Customer service like that will get my business again.
QA42 snow thrower
38" deck
44c mowing deck
QA42A snow thrower
42" snow blade
Old 12-11-2018, 01:04 AM
Vrobert's Avatar
Default Putting final touches on the QA42A
I shimmed the gearbox out from it's mounting plate to align the pulleys. I used two washers on top and 5 on the bottom. Then I added a 1"x3"x1/8" spacer on the top and bottom after I filled them into a wedge shape so that the gearbox had flat mounting surfaces.
I also flipped the pulley around to move it as far forward as possible. It lines up well with the top pulley. Pic on right is before shimming.
QA42 snow thrower
38" deck
44c mowing deck
QA42A snow thrower
42" snow blade
Old 12-11-2018, 01:12 AM
Vrobert's Avatar
I also flipped the scraper blade around and replaced all the carriage bolt with stainless hardware. Don't let it get as bad as this! There wasn't much blade left and the nuts were tricky to remove. That is the nut you see.
QA42 snow thrower
38" deck
44c mowing deck
QA42A snow thrower
42" snow blade
