#21
Thanks for the reply! My charge pump is notched to allow clearance/access to the line fitting. Plus there are clear as day marks as to how it's sits on the surface. At first I installed a Napa 1410 filter along with cheap Universal hydraulic. After I knew all the leaks were fixed and everything was running fine then I planned on swapping it out for the Cub Cadet 923-3014 Plus HyTran Ultraction fluid. Before I removed everything again from the tractor I did install the Cub Cadet filter just to see if it would change anything. Nothing changed. When it was in the tractor I did try cracking the lines and loosening the filter a bit while it was running in hopes of possibly purging the system of any air but still changed nothing.15129422311051901247735.jpg
#22
Well, I don't know what I did different! Put the pump back together, mounted it to the rearend, stuffed it back into the tractor and it works and sounds beautiful! ?????????????????????????????????????????????????? ???
#23
FWIW:
When you loosened the filter, you induced additional air into the system, as it is a suction filter. Always best to put fluid in the hydro unit when assembly is completed to insure pump/motor is primed, and nothing starts dry. ![]() Glad all is well!! |
#24
The only thing I did different this time around was instead of dumping fluid into the pump thru the inlet on the bottom before mounting to the rearend, I pulled the relief valves and poured fluid down the holes. Not sure if this helped but like I said it was the only thing I did different. I don't know!
#25
[QUOTE=Sam Mac;440471]Wheels are supposed to spin in opposite directions when you spin 1 wheel, that how a diff works.
I understand this. But when I installed everything into the tractor the first time around, with the wheels mounted on the hub and tires touching concrete, the tractor wouldn't roll forward or backward when I tried to push it. The rearend was locked. The second time around after reinstalling everything, it rolled fine when pushed. Maybe this contributed to it not working the first time. I wonder what was hanging it up? The pump shafts spun freely by hand before mounting. |
#26
[QUOTE=Big-D;440534]
it is possible something was binding during reassy, hard to tell not being there, good thing is it works well now ![]() |
#27
I agree! Thanks for all the moral support! I would be lost without this forum!
