Old 12-01-2017, 10:48 AM
swacor swacor is offline
I saw this on Craigslist, I thought the seller said it had a bad piston, did you determine that was not the problem?
Old 12-01-2017, 11:05 AM
782Smoker 782Smoker is offline
We could have bad pistons too. I haven't gotten the heads off yet. So far all i see is bent push rods. I replied to your pm.
Old 12-01-2017, 11:11 AM
Originally Posted by 782Smoker View Post
The only thing that will make my smoker better is a turbo, which is in the works.
Being that I have a bent push rod on each cylinder this may just get parted out. I bought the tractor for the deck and blade. What is a 1864 worth? It would just be the tractor. I don't see it being cost effective to fix. Please correct my eyesight if I am not seeing straight.
I'll give you $500 for it delivered to Galax VA. Complete tractor, no deck or blade.
It cost me $165 to have my 1864 shipped from PA. The shipper used Central Transport http://www.centraltransport.com/comp.../services.aspx I see that they have terminals in MN. You would need to put it on a pallet and get it to a terminal.
Old 12-01-2017, 12:18 PM
Sent you a pm
