Old 12-23-2017, 08:11 AM
ironman's Avatar
ironman ironman is offline
Originally Posted by Marko141 View Post
I am hoping I can put in a stronger battery, change the oil, clean the tank out, maybe change the plug and it fires up. That snow blower will be nice with all the snow we are going to get. And the seat was in prime condition, not sure if its original but it had no cracks or rips.
Be aware that in cold weather (and I see you are in New York) these hydros (which your 127 is) tend to turn over more slowly when starting than they do in warm weather or when already warmed up. This is because the hydro oil thickens up due to the cold and since the drive shaft is turning the hydro while you are cranking to start, there is a lot more drag on the starter/generator. If you are not in tip/top tune-up condition starting could be a problem.
Cures can be a stronger battery, keeping the tractor in a heated location, or providing a heat source such as a heat lamp or heater to warm the hydro differential case up for a period before trying to start it. Personally, I have a battery charger with starting booster option which I use. Once everything is warmed up starting is easy.
Old 12-23-2017, 09:47 AM
Marko141's Avatar
Marko141 Marko141 is offline
First will be the oil change, what oil is preferred in this engine? I'll grab some at work today and get everything worked out tomorrow.
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains
Old 12-23-2017, 10:09 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
I do I have some serious plans for the 127 though. I think for now I will just get it tuned up and everything working. Then after the Spring when I use the tiller I may take it somewhat apart and paint it all up.
Does that include a hydraulic lift of some type??
Good points made, the heated facility is always the best. But a tarp, two magnetic oil heaters and a battery maintainer would be a good alternative if you need one
1- 1200 in pieces
1- 1864 in pieces
Old 12-23-2017, 10:47 AM
athomas's Avatar
athomas athomas is offline
Looks like a good deal with all the extras ! Good battery,tune-up and proper timing setting ( static method best ) clean starter /gen . (new brushes and brgs if needed ) and starting in any weather shouldn't give you any problems, good luck !
Old 12-23-2017, 11:33 AM
Marko141's Avatar
I believe it has the hydro lift.
Old 12-23-2017, 11:35 AM
No, it doesnt. It has manual lift.
Old 12-23-2017, 11:49 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Thumbs up
Good choice!!
Old 12-23-2017, 01:57 PM
Gompers Gompers is offline
Yeah from the pictures it has a manual. There was an optional electric lift on these, but I don’t think there was a hydraulic option on the 1x6/1x7 models.
Hope there’s a spring assist on it for the tiller and blower. Those are pretty heavy to lift otherwise.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 12-23-2017, 02:00 PM
The book specifies 10w30 in cold weather and straight SAE 30 in warm weather.
Opinions on this are all over the place, but I use IH low ash 30wt in the summer and a good synthetic 10w30 in the winter. Most important thing, imo, is maintaining the proper level and regular changes.
Old 12-23-2017, 02:17 PM
Marko141's Avatar
Well enough chat about what it may or may not have. It had the attachments and rolled. I will look over what it does and doesn't have when I have time when the sun is up. At 10:30 at night it's hard to see the small things.
