Old 12-25-2017, 11:29 AM
Originally Posted by Gompers View Post
If you’ve got a wire or remote starter switch to jump 12v from the battery to the solenoid you could see if that will spin it over.
If it turns over, that would rule out the solenoid, the solenoid ground, the solenoid load cables and, well pretty much everything aside from the wiring between the switch and the battery and the switch and the solenoid.
If that doesn’t spin over, its more likely the solenoid load cables, since you just replaced the solenoid and it’s unlikely to be the solenoid ground.
Edit:
Forgot to ask, does this tractor still have the safety switches installed/connected? That could be another place to look.
Actually, if a new solenoid was installed there is a good chance it isn't grounding. Again, using jumper wires isn't a definite test. Now, if you use a power probe, it can be, as most have a digital read out that indicates volts like a meter and also has lights to indicate a complete circuit. Bad thing is, as with a meter, it doesn't necessarily indicate a circuit capable of a load.
Personally I use a test light or my power probe before a multimeter. Just because as a general rule, a weak illumination of the light will occur if the circuit is weak. I save the meter for small circuits like sensors and signal wires to a PCM. My favorite is my power probe, as it's 3 tools in one.
Old 12-25-2017, 11:45 AM
Gompers Gompers is offline
Doesn’t the solenoid ground through its body to the chassis?
Figure that would be unlikely to be it, but it would definitely match the symptoms!
I don’t like using digital multimeters to test intermittent stuff like this because its hard to see the voltage reading move around and know if that’s from the circuit or just noise from probes moving or averaging from the sampling rate or whatnot. After all, multimeters are designed to show the current level and not the level over time. That’s what an o-scope is for.
A nice power probe would be very useful and some of the fancy ones I’ve seen actually have little graphs on them to help eliminate that problem. If I did this stuff for a living I’d definitely snag one to help save some time.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 12-25-2017, 01:21 PM
Lets let the OP do some checking. He has been given some very good and concrete information. We can speculate and discuss different ways of doing things, but now is the time for him to do something.
Old 12-26-2017, 05:06 PM
countywacker countywacker is offline
Thanks for all the replies everyone. I'm hopefully going to dig into it this weekend when I'm off.
Old 12-26-2017, 05:21 PM
Chad126's Avatar
Chad126 Chad126 is offline
To second what has already been said, if you could benefit from one, I would highly recommend a new harness from this guy http://www.mikescubcadets.com/wiring-harnesses/
Very pleased with the one he sent me.
"Equality is about giving everyone an equal chance, not about giving everyone an equal result."
1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator
http://www.onlycubcadets.net/forum/s...ad.php?t=50159
Old 12-26-2017, 06:11 PM
I'm keeping that in mind for a spring overhaul project.
Old 12-26-2017, 11:22 PM
You work 24 hours a day, 5 days a week?
That must suck.....
Old 12-27-2017, 12:07 AM
That must suck.....
10 days on with 4 days off every other weekend with mostly 13 hour days on rotating shifts. So with that and family obligations doesn't leave much time to play tractor. Besides, once I start a project I like to finish it as soon as possible and not let it sit.
Old 12-27-2017, 12:09 AM
Yep. That sucks.
Just curious what you do that you work like that?
Old 12-27-2017, 12:36 AM
Yep. That sucks.
Public Safety Communications, which is also my primary hobby. You guys have garages full of tractors and I have garages full of radio equipment I just cant part with...lol
But all seriousness I've had my 149 for the past several years and I enjoy tinkering with it more and more. So I'm quickly trying to absorb all the knowledge I can.
