Old 12-29-2017, 09:27 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Originally Posted by Slycox View Post
2050066u536029
December 1974...Early production!
Queen Of The Quietlines!
Old 12-29-2017, 09:31 PM
Slycox Slycox is offline
Good to know thanks! So is there things to consider being an early production model? Any issues that were sorted out later etc?
Many thanks for answering my questions.
Old 12-29-2017, 09:32 PM
DeltaCub's Avatar
2050066u536029
Please double check your serial number...you have a weird kind code.
Old 12-29-2017, 09:38 PM
DeltaCub's Avatar
Good question...nothing significantly different that were major issues on the early vs later models. Check and/or replace things like driveline stuff (usually worn out), engine mounts, engine cradle modification, muffler box...there are other things but the items I have listed and the stuff others have mentioned in previous posts are the most common.
Old 12-29-2017, 09:48 PM
Here you go
Old 12-29-2017, 09:55 PM
DeltaCub's Avatar
Here you go
Thanks...I think it is a misprint from my reference source. Still built in December 1974.
Old 12-30-2017, 01:02 AM
Heres some more pictures
Old 12-30-2017, 02:22 AM
Rmowl's Avatar
Rmowl Rmowl is offline
Nice 1450 and implements. Did it come with the side panels too?
-Rick
IH 782
IH 126
CCC 1863
Old 12-30-2017, 02:39 AM
Yes those are there, they had a soft cab attachment that apparently interfered with it.
Old 12-30-2017, 02:40 AM
Originally Posted by sawdustdad View Post
After bringing home several (10?) non-running Cubs, here's what I would do with it--
1. get it running. Disassemble and clean the carb. If you have an IH dealer nearby, pick up a rebuild kit for the carb, but it's not mandatory for this quick and dirty exercise. Drain and refill the fuel tank, and get clean fuel to the carb. Put the carb back on.
2. crank the engine with the plug out and lying on top, touching a head bolt (or otherwise ground it) to check for spark. If no spark, pull the points cover and clean the contacts. That solves 80% of the no spark issues.
3. With a spark, put the plug back in and crank it, with some fuel squirted in the carb if needed. All of my ran at this point.
4. If it sparks and doesn't run, come back on here for more troubleshooting advice.
As far as #1 goes if I can't find an IH dealer nearby where is the next best place for carb kits and parts?
