#21
Hey Wayne, sorry that you were soaking the wrong screws. I assumed (incorrectly) that you knew which screws I was talking about. It sounds like you need a new thrust button that uses the C-clip, like this one....
https://www.ebay.com/itm/CUB-CADET-P...ss!46220!US!-1 Hope your lawn isn't very large if you are going to push mow it. You could arrange something like this..... https://www.youtube.com/watch?v=QRU-oqIpxiQ Cub Cadet 123
#22
It is interesting that you are going through this Wayne. I was just mowing my mother-in-laws lawn and the mower started running rough and white smoke puffed out of the front of the mower. It smelled like a burning clutch. Now my PTO will not disengage, no matter where I have the handle. I am guessing I somehow cooked the clutch in the PTO, but I am not sure? Can't tell from outside inspection.
I just bought my 128 a few weeks ago and was hoping to get through the summer and do a full restore/rebuild in the winter, but... Is it normal for these to blow white smoke and stink when they fail? |
#23
But I'd need my Cub running to do that. I only have ohh, 2 acres or so. But after an hour of mowing with the 20 inch push Rally, I only have about 1.95 acres left though.
Cub Cadet 2166 |
#24
Cub Cadet 2166 |
#25
Bearing could have went out, but that wouldn't have caused the smoke, and wouldn't have affected anything with the PTO on. The bearing is only used when the PTO is in the "off" position. If you slipped the clutch and it got hot, it should still disengage, and it doesn't usually make a "puff" of smoke. Rolling smoke is more common when a spinning object gets hot and starts cooking. You sure you didn't blow a head gasket and the PTO just needs adjusted? That sounds far more likely. |
#26
Wayne,
When you get to the point of removing both set screws that are in each hole in the pto belt pulley............. Make darn sure you have the proper size allen wrench going into the set screws. They are an inch and more down in those holes. You have to kinda feel the allen wrench going into the set screws a good amount. And your allen wrench should have a fresh, like new end on it. Sometimes I use a grinder to "dress" the end so that it is square to the length and sharp cornered. The worse thing to deal with is if you end up rounding out the hex in the set screws. And when backing them out work them back and forth out of the holes. Sometimes if they are really resisting I will run a tap into the holes to clean out the threads, and blow them out again with air. |
#28
And what is my goal here? Am I going for the bearings or something else in/behind the pulley? I'm wondering if this might be a job I should farm out. I'm in a rare situation where I could actually pay someone 1 or 2 hundred dollars if this is going to end poorly doing it on my own.
Cub Cadet 2166 |
#30
