Old 06-20-2018, 10:01 PM
Nato527 Nato527 is offline
I flipped the link around where the s part of the bend is towards the steering arm. ( like it should be) . It seems way better. But it’s dark out , not good for test drive. Ha! Now I’m trying to compare pictures of the 104 and 125 front end. Think I’m going to have to go get it from dad this weekend and do some side by side comparison. Maybe swap him out and hope he doesn’t notice.
File Type: jpg AA55D388-7CC9-49CC-9B26-B925A559DA02.jpg (32.8 KB, 75 views)
File Type: jpg 7DC52753-D5CF-4D81-96D7-B980878BDC8D.jpg (38.4 KB, 76 views)
File Type: jpg FCC93B91-A903-4FD2-92EF-5DD6CE74F4E1.jpg (25.0 KB, 77 views)
Nate
Old 06-20-2018, 10:09 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I know that.....
I was just giving information since all that was brought up.
However the length does matter. Put one on that's too short and tell me things don't change.
Yes.
Meant to say drag link length does not matter as long at it corresponds/coincides with wheelbase change.
Old 06-20-2018, 10:13 PM
DoubleO7's Avatar
Or go to cubcadet.com link above and compare part numbers of components between the two.
I think you will find all of the parts are the same numbers.
Old 06-20-2018, 10:38 PM
SLS327 SLS327 is offline
Did you measure and adjust the toe?
Too short a tie rod will cause this. The front of the rims need to be closer together than the back, theres a setting in the manual.
I think its great you tried this.
Steven
__________________________________________
127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720.
Old 06-20-2018, 10:46 PM
Billy-O's Avatar
Billy-O Billy-O is offline
You need headlights! Cub Fever!
Plow blade
#2 Cart
QA36 snowthower
Old 06-20-2018, 10:50 PM
The stock front ends on a 104 and a 125 are the same.....or do you mean the C axle 125 and 104?
I'll save you the trouble...they're very, very different.
Old 06-20-2018, 11:14 PM
The c axle 125 and the stock 104 of my dads. I’m just not seeing the tires being that much different as far as being foreword 3 inches. But I could be wrong. Btw I like the new name ..... c axel 125....
Nate
Old 06-21-2018, 12:34 AM
I measured the two I have sitting here. It's "about" 3". Might be 2.75". I verified the distance from the center of the rear axle to the front of the bolster is the same, then measured the wheelbase of both.
Old 06-21-2018, 09:45 PM
J-mech , you might have me on cub knowledge, but not reading a tape measure. Just giving you a hard time, I'm thinking your front end isn't a " straight axel ". It's kicks the wheels forward. Probably a different Cyclopes....
Nate
Old 06-21-2018, 09:47 PM
Dads 104 stock
Nate
