Old 08-02-2018, 02:50 PM
Originally Posted by samiam44 View Post
I guess tomorrow night I'll just start pulling somethings apart to investigate. I thought I should be able to narrow it down to a definative problem- but now I think visual is best. I'll get the muffler shroud off and poke around. I'll look at the headgasket area closely as possible around the exhaust valve area.
In the end-I think I've got a spare gasket- so I can pull it if need be. Seems like it takes me a bit of time.
Make sure you resurface the head.
https://youtu.be/L1jFtTzLh7o
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-04-2018, 01:08 PM
samiam44 samiam44 is offline
So what the heck?
I've got the cover off and done quite a bit of washing. There is oil- maybe the front seal, head gasket looks good around the exhaust port from what is visual. I believe it is OK.
Possibly I a front seal leak. I degreased and pressure washed it all well.
The noise- there is something loose in the muffler on the 1650. It is a metallic rattle if you hit it hard. That could account for the sudden noise change.
I changed oil /airfilter for grins and will go cut the yard. See it it throws more oil. Maybe it's oil from missing the filler tube?
Cub is old- but boy do I love cutting with this old CC!
Old 08-04-2018, 01:39 PM
Missing filler tube?
Old 08-04-2018, 01:56 PM
Ok,
Definately a bad seal- not a dripping seal but it's really a gusher. My Kohler hard copy says the PTO seal can be installed flush instead of 1/8 set back for a clean sealing surface.
What do most ppl do... Off to buy some more gunk degreaser.
Old 08-04-2018, 02:14 PM
With an electric PTO, it has to be inset some.
Old 08-04-2018, 04:32 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
I set mine in 1/8" on my 1250.
Randy
1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift
