#21
![]() Quote:
#22
Yes, Power problem as I have stated already.. A little oil might make it so your weak battery has an easier time temporally.
#23
I'm sorry you aren't familiar with this issue Coop. You learned something new today.
Even if it does need a new battery, it doesn't take this may posts to figure it out. |
#24
![]() Quote:
And you did not answer the question.
#25
![]() Quote:
#26
I agree with J, lube the bendix shaft. Do it to dads 1811 about every 2 years. For whatever reason it seems to hang up (or in this case, in) just about the time for spring oil and filter change/blower removal.
#27
Every 2 years I can see.. 3 new starters within a few months tho?
#28
Ok, here it is- I got my meter out and rang out the battery cables. I looked at the harness as it went under the cowling against the frame, and while some of the electrical tape was worn so I could see the wires going to the head lights, is was just the electrical tape that showed any real wear. The battery before I started this was at 12.52 volts, and the tractor had been sitting since Sunday. I pulled the starter, got a small screwdriver and some 3 in 1 oil. I put a couple drops on the front of the shaft, advanced the gear with the screw driver, and put a couple drops on the back side of the shaft. I worked the gear back and forth with the screw driver. Reassembled. The tractor fired up first try. I got out my meter again and measured 13.92 volts while running. I shut off and re started the tractor 5 times. If the problem returns in a short amount of time, I'll say this wasn't the solution. but....until then. Thank you all for your help and kind advice helping me keep my tractor running.
#29
How about this test.....???
What is your voltage, as measured with a VOM or DVM, at the starter (Large Terminal to ground).....while the engine is turning over..?? ![]()
#30
I will try to get that measure tomorrow.
