#21
Randy 1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift |
#22
Is that Little bolt to hold the cooling fan on, or does it hold the shaft on?
Up to 534 and counting... I give up updating my profile! |
#23
There is a long bolt that goes all the way through center and threads into the tapered shaft. I used the same bolt that held it to tapered shaft on the original engine. Its the shaft bolt. Fan is held on by small screws
#24
Ohhhhh, Now I remember, I took one of those off one time, never did find a motor for it so I chucked it.
#25
Oh, Your engine was no good? This one is fine but after seeing the gen set attachment I figured this would be more useful around the yard than lugging it around as it was. Someone will have a need for the 11HP I hope.. Or maybe it will also get re-purposed.
#26
Yes it was no good, that was 12 years ago I chucked it.
#27
Coop - how do you plan to address the need to run the gen at a fixed rpm to achieve 60hz output? Could you mark the dash and position the throttle lever to certain point? Do you think the Kohler governor will respond enough to keep synchronous rpm under load? I maintained some large gensets over the years and throttle/load settings were always touchy. Voltage fluctuations can burn up an AC motor if you're not watching the output.
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
#28
#29
Small engine gen set governor's are made different than those in tractors. Same on Kohlers. (And Detroits, ect, ect, ect...) Completely different flyweight mechanism. Just saying.
No, they are not any more "complicated". Just more sensitive. I will ad, that I agree keeping the Hz under control is important, but as long as you understand what you have, it shouldn't be an issue. No different than the old Pincore units, or a tractor driven PTO generator. |
#30
