Old 09-25-2018, 02:13 AM
Not sure what the manufacturing year has anything to do with it. It's not fuel injected or computer controlled. Still just a carbureted engine with magneto ignition. All it needs to run is a fuel supply, 12V to the fuel solenoid and a starter. Like I've stated many times before, an engine only needs 3 things to run; fuel, air and fire (ignition). Sounds like you have it narrowed down to a fuel issue. If you don't understand the next step, refer to posts 13 and 14.
Old 09-25-2018, 09:10 AM
Need to clarify the "Ignition" with "at the right time"
Had a sheared flywheel key lead me down a head scratching path one time.
( I know Jon knows this)
Old 09-25-2018, 09:49 PM
Steve62 Steve62 is offline
Good point ! I had a Kawasaki 750 SXI jet ski back in the late 90's and went off a big wake, hit the water hard and it immediately started running terrible.
After hearing opinions from 25 "experts" (including me) and checking everything multiple times I finally realized...timing !!
Pulled the flywheel off and there it was, sheared key ! I was SO happy to see that. I guess the impeller bit into the water hard and the flywheel rotated just enough to shear the key, then since it was running so bad, never got under load or shock enough to rotate any further on the crankshaft.
Anyway, I'll always remember how happy I was to see that key sheared and that's all it was.
