Old 11-10-2018, 01:26 PM
35boulder's Avatar
35boulder 35boulder is offline
Originally Posted by Tom Dowling View Post
Just saying,,, that cinder block is on the weak side turn it 90 degrees to the strong side. They aren't meant to hold weight on the side and can collapse without warning.
Thanks for the heads up, just resting on it to keep pressure off tires. And as stated it is on the end of the block. Thanks
Old 11-10-2018, 03:57 PM
jbrewer's Avatar
jbrewer jbrewer is offline
That is in REALLY nice shape!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 11-10-2018, 06:52 PM
ironman's Avatar
ironman ironman is offline
Originally Posted by dodge trucker View Post
Forget the new imitation carbs from China.
Kits for that carb are readily available, be sure to check the throttle shaft for slop within the casting, they can be bushed.
I bought a kit for a K301 carb. I am not a novice at rebuilding these things but it ran as bad after the kit as it did before. Had the carb off and apart, re-cleaned and inspected prolly a half dozen times with never any change or improvement. In the mean time I placed an order with wun hung Lo for a clone carb that cost only the same as the kit I bought for it. China carb arrived and right out of the box made the motor run like brand new. I have since purchased 3 more of these carbs for other projects and have had no problems.
Everyone is entitled to their own opinion, mine is that I'll never rebuild one of these carbs again as long as a new carb is available as cheap as a rebuild kit.
Old 11-10-2018, 07:03 PM
Bamafan Bamafan is offline
Inactive Member
What he said, have replaced 2 after rebuilding the old ones. The old ones are on the shelf now. Wish I had bought the yang ones before wasting money on the old ones.
[B]Larry[/B]
Old 11-10-2018, 08:59 PM
IHCubCadet147's Avatar
The Chinese carb I got for my 129 has been working good. I had to adjust it even though it was supposed to be set and tested, but other than that I'm happy with it. I was only going to use it until I rebuilt the original, but as long as it keeps working good, I'll keep it on.
Old 11-10-2018, 09:02 PM
cooperino's Avatar
Theoretically you should always need to adjust any new carb China made or not. Impossible for them to already be tuned to exactly how your engine is running. They should however come preset enough to start and idle as long as theres no other running issues.
Old 11-10-2018, 09:09 PM
It said it was tested, but I didn't really believe it. It ran, but not very good.
Old 11-10-2018, 09:32 PM
sawdustdad's Avatar
I've been hesitant to try the new Chinesium carburetors. Though, from what you guys are saying, I should embrace them. I have one of them on the shelf that I bought off ebay last year for more like $50, but I've got 4 or 5 original spares that I rebuild and rotate, so I have never found myself needing a "new" carb. I just ordered a couple more tonight, after seeing the links, at less than $15 how can you go wrong??
I do have a 1250 that seems to be a bit finicky on carb adjustments, so I might try that one with a new carb. The rest of the fleet run pretty well on their original carbs. I do have three engines waiting to be rebuilt, two K241s and a K301. Will get to them this winter, or at least a couple of them. One does not have a carb.
Old 11-11-2018, 11:51 AM
35boulder's Avatar
So, when you use one of these replacement carbs are you able to reuse the "hard" fuel line or do you replace with a rubber one? Thanks
Old 11-11-2018, 12:00 PM
Rmowl's Avatar
Rmowl Rmowl is offline
Yes you just have to remove the threaded 90 from your original carb and put on the new one. Check to make sure the bushings don’t leak
-Rick
IH 782
IH 126
CCC 1863
