Old 11-29-2018, 12:58 PM
ccpullin ccpullin is offline
Originally Posted by Camarors8992 View Post
Here’s my trunnion issue. As you can see, every part of it is worn. Might be better to replace with new? If available of course. Also, I was going to drop the transaxle to work on the trunnion just for ease of access but one hydraulic line isn’t having it.
I tried uploadinf a video but it wouldn’t let me.
In order to replace the trunnion the hydrostat must be disassembled and there a few things you must know first before disassembly (half length roll pin in trunnion shaft to swash plate, swash plate alignment (install backwards and goes like heck in reverse and slow forward)).
Looking at the picture, it does not look that bad (need to see better picture) possibly just weak springs. Usual issues are slop in linkage, adjustment, and weak springs. I have found replacing the two springs along with placing a flat washer the size of the outer spring on each end of the spring under the spring pin guides will really speed up and increase the reaction of the hydro. Down side to the washers installed is you have to feather the hydro lever on take off or it will take off harsh and immediately. I have mig welded them before although they were in much worse condition than what I see in the picture posted. After new springs/washers installed there should be no free travel of the trunnion in damper plate.
Old 11-29-2018, 02:16 PM
Camarors8992 Camarors8992 is offline
I’d buy you a case of beer if I could for you help haha
I uploaded my video to YouTube, here it is
https://youtu.be/SJj8OpUntC8
Old 11-29-2018, 02:58 PM
Xtreme makes some parts to repair the trunnion.
http://www.xtrememotorworks.com/Part...Cub-Cadet.html
Old 11-29-2018, 03:53 PM
Yes, the linkage is a little loose here and there because of its age and use. It appears your main issue is collapsed springs. Don't pull the rear axle out yet. Pull the tunnel cover and LR tire off then you can get a pair of snap ring pliers through the inspection hole in the frame to remove the snap ring for the damper plate. Then pull the snap ring off for the control cam plate. You can now slide the damper plate over far enough to install new springs and washers. Install 2 new springs from Cub Cadet, place the washers as I instructed you, then compress and slide them all in. Reinstall the snap rings, install tire and adjust the drag on the hydro control lever nut then take her for a spin. I think you will find the springs will repair 90% of the issues you are having! If everything is fine and neutral is right, install the tunnel cover.
Breakdown Picture
https://www.cubcadet.com/equipment/A...0-A/0030900050
Old 11-29-2018, 06:01 PM
Gompers Gompers is offline
Breakdown Picture
Might also want to shim up that damper plate to help eliminate the side to side play. That changes the geometry of the linkage enough to cause issues sometimes. It's a 5/8" ID shaft. I use https://www.mcmaster.com/3088a323 for that job.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 11-29-2018, 06:51 PM
I’ve got my hands full.
File Type: jpg 4FF4346B-3337-4426-92EC-86AECC532961.jpg (38.3 KB, 100 views)
Old 11-29-2018, 06:52 PM
Hah! The cub cadet trunion service position. You won't regret getting that fixed.
Old 11-29-2018, 07:09 PM
Haha that and I wanted to paint the frame. Also had to put a new fender pan on, fix the broken dash, service the transaxle, and now fix the trunnion and driveshaft coupler. I went in head first, I’ve never had one apart lol
Old 12-02-2018, 06:23 PM
While waiting on parts to come in the mail, I’m cleaning the tractor up. Does anyone have any idea what these holes would be for?
File Type: jpg 0A0228A9-F62C-46FF-AE33-1015D7FCF36C.jpg (17.9 KB, 61 views)
Old 12-02-2018, 06:29 PM
sorner's Avatar
sorner sorner is offline
Ventilation for the brakes?
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
