Old 11-29-2018, 05:36 PM
cubs-n-bxrs's Avatar
Is your cutting edge hitting before the skid shoes touch the ground? That would cause some serious drag. I run a 45" blower on the front of my 1641 and don't have nearly as much weight as you and I very seldom spin a tire. I'm running 23x10.5x12 turfs with 2 link chains with 65lbs of weight on each tire.
Old 11-29-2018, 05:42 PM
ejl6658 ejl6658 is offline
Default Tire Suggestions Please??
One issue with steering with the blower down are the steel shoes/slides on the blower. They don't like to slide sideways which causes lack of steering control. Replace them with hdpe/poly slides or add hdpe to yours, it really helps.
TNTs CC
The original steel slides on my blower are about wore out. Do you have a link for the hdpe/poly slides.
Old 11-30-2018, 03:27 AM
hemimike hemimike is offline
I got a pair of Kendra Bear Claws in the garage. I believe there 25x10-12, but they could be 25x8-12. Guess I'll have to check. Like the homemade 3 point hitch!
Old 11-30-2018, 07:55 AM
Ok, just checked my bear claws and they are 25x10-12. Factory are 24 or 25x10.5-12. Will they fit on there?
Old 11-30-2018, 08:42 AM
Trying to mount them now. Will update soon.
Old 11-30-2018, 11:29 AM
Well got one on. Had to do the old brake cleaner trick but it's on. Seems to be holding air ok and don't see any rubbing.
Old 11-30-2018, 05:27 PM
I think you will see a big improvement in traction with those tires if you had original turfs on prior. Unique using the front bumper for a rear suitcase weight bracket. Never saw anyone do that before.
Old 11-30-2018, 06:04 PM
Had to try them out. Got stuck couple times but was able to back out.
Old 12-01-2018, 03:46 AM
Well I didn't drive through the snow in the yard with the turf tires, that was more of a curiosity thing. Won't really know until the next snow fall when I try blowing it. Tell you what though, I feel bad for you guys that don't have the differential lock.
Old 12-01-2018, 06:56 AM
dale c. dale c. is offline
I'd be worried about the outer axle bearings with that much weight hanging on the tractor . did you fill the tires with antifreeze ?
