Old 12-05-2018, 02:14 PM
A self locking nut will eliminate a lock washer.
Or you could go to the trouble of drilling the bolt and using a castle nut.
I do not think there is room for a castle nut,,,
The nut shown being used in the pics is a jam nut,,, VERY thin,,,
Old 12-05-2018, 04:56 PM
AL Farmall Boy AL Farmall Boy is offline
Now here is an idea from McMaster car. Have any of you used this? What do you think? A shoulder bolt!
File Type: jpg 2A1BC274-E620-4050-A9A4-1F50FD0BCA5A.jpg (26.4 KB, 211 views)
Old 12-06-2018, 09:08 AM
AndrewNoyes AndrewNoyes is offline
Interesting idea. I don't believe you'd be able to thread deeper if needed, I believe they are quite hard. I also am a little unsure how well one would take a shock load. It might fracture. They are very precision. If you need to thin the head, the hex socket might be a bit shallow. But I guess if you have problems with it, you can simply replace it.
Other than those concerns, it seems like a cool idea to me.
However, for my tractor, i think I'd still prefer a grade 5 or 8 hex cap screw.
Good luck!
Andy
Old 12-06-2018, 11:07 AM
While you are in there, check the bushings for wear or damage.
It does happen!!
Don't forget the grease valley in the bolt if you go that route.
Old 12-08-2018, 01:21 PM
GERKS 149 GERKS 149 is offline
Someone needs to make a bolt like this and sell it. Probably a lot of takers here
Old 12-08-2018, 01:29 PM
Probably cost more to machine the grease valley in a hard bolt than anyone would pay for it.
Damn near $10 just to ship one of them.
Old 12-09-2018, 01:17 PM
I would pay the price for a good bolt made the right way that could squeeze the axle and have the grease valley made into it. Nobody makes one yet. It would sure solve the problem for many Cub lovers
Old 12-09-2018, 02:55 PM
sawdustdad's Avatar
In order to squeeze the axle it would have to be too long to remain in place without cutting one end off.
I think the OEM pin will provide the best results, proper fit in the bore and the correct hardness for the application.
Old 03-29-2019, 08:34 AM
Simple.
Use along enough bolt (with the axle removed of course) to squeeze the channel back to spec's, remove it, and replace with the correct length pin or bolt.
May take several snug ups to et it back to spec as it will spring back out some when backing off the nut.
That's what I do w/all my cubs when they are on my table.
Nothing like a nice, tight front end and steering assembly.
Makes these little machines a joy to drive!
Old 03-29-2019, 10:16 AM
Simple.
X2 on that,
a tight front end is always a good thing!!
