#21
Is anyone else out there biting their tongue or is it just me?
#22
I bit my tongue at dinner last night. I hate that!
![]() Had to take my dentures out, ruined the rest of the meal. |
#23
You can pull the grille screen out if you don't have enough clearance. You should have enough clearance though. I haven't messed around too much with 100s, but the "push the PTO forward to get enough clearance" is the way you get the belt onto the PTO on manual PTO clutch Cub Cadets.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240 |
#24
It looks like the front grill is bent inwards a little bit. As it was said before, you can pop the grill out to make room. Or, just use a little muscle and push the grill forward just enough to make room to remove the belt.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
#25
Okay, here is the secret, remove the hood, then loosen the four bolts holding the grill housing and then tip the grill housing away, forward.
Works for me.
Up to 534 and counting... I give up updating my profile! |
#26
Thanks to those who offered suggestions.
#27
Is the lever just hitting the grill? Will it open further with grill removed?
Edit. Just saw Darkminion suggested this
