Go Back   Only Cub Cadets > Resources > Technical Library - Tractors
Closed Thread
Old 11-03-2014, 10:03 PM
Merk Merk is offline
Clutch is back in 100. I installed the blade and push some dirt.
View from the front:
70 wanted to get involved in moving dirt:
Project Uncle Dick
Cub Cadet 70
  #22
Old 03-01-2015, 09:04 PM
Here some great drawings to identify the different parts of a narrow frame clutch assembly:
Thanks Craig Cambell for the drawings!!!
Project Uncle Dick
Cub Cadet 70
  #23
Old 05-28-2017, 03:13 PM
Materials used to build my clutch fixture:
The material used is 1/2 X 2 inch.
The angle iron is 1 1/4 inch.
The threaded rod is 1/2 thread.
The length of the threaded rod is 18 inches.
Overall length of the frame is 22 inches.
Height is 8 inches.
The bushing that goes between the threaded rod is 4 1/2 inches long and 1 inch outside diameter. The end towards the threaded rod is 1/2 inch diameter. The ends towards the clutch assembly/driveshaft is 5/8 inch diameter. Part was made on a lathe.
Threaded rod end:
There was a 1/2 nut welded to a flat piece of steel. This nut/plate was welded to the uprights. Centerline height is 7 inches.
End that holds driveshaft in place:
Shim stock was used to get the 5/8 spacing for the drive shaft. Support piece is 6 3/4 inches.
Clutch holding fixture was built by my Son in his high school ag shop.
Project Uncle Dick
Cub Cadet 70
Closed Thread
