#21
The collar flange needs to go over the blade if it isn't already.... So the U design needs to point towards the deck not the ground...
#22
Here is a closer Pic. Let me know if that looks correct?
#23
Yea that looks right in the other pic it looked as if you had the square stock under the blade...
#24
Ummmm is it me or are the blades on upside down?? Right side discharge correct?
#25
It is right side discharge. Those are high lift blades. Closer pic attached for confirmation.
#26
Wow... had to go back and stare at that pic.... !!! You are GTG at this station... go see your drill sgt and move to the next station.
#27
Thank you, appreciate you taking the time to look.
#28
Tractor is running great. Its rolling coal up the steep hills while cutting grass.
#29
1 more question regarding the 60 inch Haban. The rear mower wheels. Looks like the left side is inverted in. Should these wheels be further away or closer to the rear tractor tires? See pic.
