Old 07-12-2019, 07:04 PM
twoton twoton is offline
You have a bench vice?
Old 07-12-2019, 07:52 PM
Wayne Wayne is offline
Yep. The spring is already off. Nobody was injured.
This clutch is toast. The only part I'm not sure of is the release arm, because Merk's tutorial says it shouldn't be worn excessively and I am not sure when the wear becomes "excessive". Its definitely well worn.
The shaft is worn at the bearing area, so that's gotta go. The drive pins are worn so the drive plate has to go.
Cub Cadet 2166
Old 07-14-2019, 01:42 PM
ironman's Avatar
ironman ironman is offline
If all that's bad are the pins, you can spend 60 bucks for a whole new drive plate or 5 bucks for new pins.
https://www.grainger.com/product/FAB...chQuery=41lw92
Old 07-15-2019, 09:53 PM
Ah...good idea. I haven't taken the plate out and I didn't know the pins were removable. I think/hope the plate is OK...
Edit: I hadn't read Merks tutorial closely enough. I see now about the drive pins.
Cub Cadet 2166
Old 07-16-2019, 08:58 AM
Merk Merk is offline
I would change the bushing in the 3 pin driver while you have the clutch apart.
Project Uncle Dick
Cub Cadet 70
