Old 01-15-2020, 09:22 AM
Sounds like a PTO issue. You can remove the PTO & observe for "wear & tear", see if something fell into it, and/or look for damage.
If the motor runs fine without the PTO, then you know it is positively a PTO issue.
Old 01-15-2020, 10:49 PM
IHCubCadet147's Avatar
If I take the PTO off, can I use the tractor without it for a while without damaging anything?
Old 01-16-2020, 08:22 AM
No reason you can't.
Be a good time to do some housekeeping in that general area as well.
Old 01-16-2020, 09:56 AM
Like what?
Old 01-18-2020, 10:32 AM
Bob95065 Bob95065 is offline
Your PTO may need to be adjusted. Look at page 2-81 in the service manual https://www.onlycubcadets.net/forum/...ead.php?t=4644
I had to do this on my 1000 for the same reason. It was easy to do and the metal on metal noise went away when it was completed.
Old 01-18-2020, 07:45 PM
Riley Henderson's Avatar
Riley Henderson Riley Henderson is offline
X2 what Bob 95065 said my 1200 did that a couple years ago out of the blue and adjusting it helped. Be aware though it may not take much mine was a very very slight movement. Best of luck getting it going again.
IH cub cadets 800x3,1000,1100,1200x2,1250DS,1450,1650DS, 71,122x2,123, 73x2,106,107,126x3,127,147x2,86x3,128,149, 169x2 ,Original, cadet 55, to name a few
CCC machines
1282,1050,2072,1535,1440
Old 01-19-2020, 01:58 AM
Thanks for the suggestions. I adjusted it a couple months ago when I changed the oil seal. I already took it off, but I’ll get it back on one day and readjust it and see if it goes away. I don’t see any obvious wear or damage.
I ran it for two and a half hours tonight plowing snow. It ran much better, and even seemed to start easier and have more power. I’m thinking the head may have been cracked since before I got it.
