#21
He’s talking about a Quietline, the driveshafts in them are a little different than your 129.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
#22
I'm not a FB member so even having found his site, I wasn't able to contact him that way; however, did a search on his name and found a phone # so I left a message for him to get back to me. I'd like to see more detailed pictures of this split fan. I wonder how good it holds up? It'd be interesting to speak to someone who has been using one of these for a decent length of time. Surely would be a bummer to have the thing eventually fly apart at higher rpm and wind up damaging something. |
#23
I never liked the idea of hose clamps at 3,600 Rpm on a plastic fan. I would think about balance. Even a few grams off at that speed will be pounds slinging around and I want to keep the charge pump and all things connected to minimum wear as much as possible. There's already enough flex with factory couplers.
#24
If he’s gone through the trouble of manufacturing them, I’d guess they’re balanced. They might even lock in place better than the replacements available. Those certainly are brittle, at least the one I bought
#26
I got more info from Rich. It looks to be well made. Says he's used it now for over a year with no problems, including doing alot of plowing. I think it's worth a shot. One thing I plan to do, however, is check to make sure everything's tight every so often.
#27
A little crazy glue on the cut area will help keep it together when you tighten up the bolts.
#28
Al I can say is what a damm fine idea
Oz
My wife says I do not listen , at least I think thats what she said |
#29
The OP posted about a 1250 so that's what I addressed my reply to.
#30
Good idea! Thanks.
