Old 08-29-2020, 07:00 PM
It certainly wouldn't hurt to dip the valves into some hydraulic fluid before installation.
I don't know if there is a Torque Specification. I have tightened them down with reasonable tightness and have not had an issue(s).
Old 08-30-2020, 08:41 AM
Just to note, The sealing is done by the "O" ring so they would actually seal and not leak just hand tightened.
But they could work loose, so as Roland says, reasonably tight.
a good guess is maybe 1/2 as tight as a spark plug.
Old 08-30-2020, 05:19 PM
three4rd three4rd is offline
So given that I'm using a half-inch drive, sounds like I certainly don't have to crank on it very much. Both were really tight, but that doesn't mean the new ones have to be set that way. Certainly wouldn't want them to work loose though and will check them after every time I use the tractor, at least for awhile.
Old 09-05-2020, 05:21 PM
I got the rebuilt manual valves from Mactech. I noticed that, with the one, when I press the button it only comes back up part way and the other one is very sluggish. Is that ok, or should they be more responsive and come all the way up?
Old 09-05-2020, 05:28 PM
Dart1917 Dart1917 is offline
That's probably just the drag of the "O"rings inside. They should pop right up with a little pressure behind them when you start the tractor.
Old 09-05-2020, 06:31 PM
That's what i was thinking. So time to take mine out and ship them to him.
