Old 11-28-2020, 01:46 PM
CubbyRI CubbyRI is offline
thanks guy thats *very good* info. so u say u ran the loader off the ported hydro, but you also had power steering? or did u mean that the loader cutting out?
any video of the loader with the hydro pump?
anyway I like the idea to run a pump off the back side of the hydro pump like in the link that twoton posted (mostly because I'd have to find and buy a ported hydro anyway) https://www.onlycubcadets.net/forum/...807#post288807 .
Originally Posted by guyina4x4 View Post
I ran my 2084 loader off the hydro pump for about a year.
ya it was kinda slow but I've since changed to a front 6gpm pump and for the cost it wasn't worth it. it worked fine off the hydro.
IMO the real problem while running the loader off the hydro was that the power steering would cut out from time to time. I think this was because the rear end doesn't hold quite enough oil?
Model 100 Dec 2020 - Running condition, has snow plow!
Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one
Model 100 Feb 2019 apart for total frame-off / sandblast etc resto
Model 70 Sep 2020 needs total resto and an engine, or for parts
Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts.
two spare hydro rears
"in for a penny, in for a pound!"
Old 11-28-2020, 09:50 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
2084's come with PS
loader always worked fine
the PS would fade with the bucket up about middle of the range.
I always thought it needed more fluid than the rear could hold.
I think this is the only known video of it in action, Son is running it
https://www.facebook.com/10001298401...7245758384885/
JD x475
Old 11-28-2020, 10:42 PM
thanks guy...
the video said "This Content Isn't Available Right Now" would love to see it tho
thanks for the info on the PS. I agree and a supplemental reservoir may have helped perhaps...
Old 12-03-2020, 08:41 PM
sawdustdad's Avatar
I think you'll want a joystick type valve, as most loaders come with a single lever control. Here is a twin spool, open center, with float valve.
The advantage of a joystick valve is you can lift/lower and curl the bucket at the same time. You'll want to be able to do that.
https://www.surpluscenter.com/Brands...57-9-12475.axd
Old 12-03-2020, 08:51 PM
sawdustdad's Avatar
Here's an easy way to mount a hydraulic pump without using your PTO. It is mounted behind the hydro and driven by the hydro's rear input (output) shaft. The pump is inexpensive, and the mounting process is not expensive if you have the fab skills.
I can't take credit for the idea, somebody else posted this method, I just copied it.
This is my tandem and the pump drives the hydraulic dump bed cylinder. The tractor did not have a ported hydro.
Old 12-04-2020, 01:32 AM
sawdust thats some cool stuff you have!
Old 12-04-2020, 08:24 AM
eberner's Avatar
eberner eberner is offline
Sawdust,
Can you provide details on the pump in the picture?
Old 12-04-2020, 08:33 AM
ironman's Avatar
ironman ironman is offline
Originally Posted by eberner View Post
Sawdust,
He has a thread on the build of the tandem pictured, you can probably find the specifics there....
https://www.onlycubcadets.net/forum/...ad.php?t=50847
Old 12-04-2020, 12:28 PM
eberner's Avatar
Thanks Ironman!
Old 12-04-2020, 12:39 PM
Thanks Ironman!
this was also shared a few posts back. same clever rear pump setup, great pictures of it
