Old 12-07-2020, 12:39 PM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
IIRC, the "L" terminal is not for an indicator light, but rather for "load". The concept of it is that it would be wired up to something that would put a "load" on the electrical system or specifically the battery. This way, the voltage regulator could use this terminal to take electricity from the starter-generator and send it directly to the load, therefore decreasing strain on the battery.
The 2 main examples of this load are lights, and electric lift.
It's good that the hydro fluid still seems somewhat normal, means there's less of a chance that anything is broke
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 12-08-2020, 02:19 PM
CubbyRI CubbyRI is offline
Got the "better" tower. Deep pits had been painted but at least not rot thru. At least not all the way thru! The welded tabs have expanding rust, so they'll have to be reworked but its better than i got. Also, new rear tires and tubes showed up. The tune up stuff showed up. And the front stub spindles and 5 bolt hubs from ebay are on the way... no frt tires yet, looking for some 5 bolt 8" wheels and 16x6.50-8 tires that are hopefully load range D
Still gonna be on lookout for a truly rust free tower. What models also had this tower? 122? (dont need the hydro lever hole going with foot control) Others?
Model 100 Dec 2020 - Running condition, has snow plow!
Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one
Model 100 Feb 2019 apart for total frame-off / sandblast etc resto
Model 70 Sep 2020 needs total resto and an engine, or for parts
Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts.
two spare hydro rears
"in for a penny, in for a pound!"
Old 12-08-2020, 05:03 PM
oh, now he tells us, a 102 122 will work...
Up to 534 and counting...
Old 12-08-2020, 05:07 PM
LOL what didnt I tell u? just saw the actual shape of the tower. Its still better, has a throttle and was $20 bucks!
Also, ordered a couple wheel/tire combo from eTrailer. 5.70x8 Load Range C - 5 lug about $75 to my door for the pair. Later I'll source the widers but these will be bolt ons no mounting needed and fairly cheap.
Old 12-08-2020, 05:16 PM
That you were putting a footsy control on it, then you could have used one from a 102 or 122...
Old 12-08-2020, 05:35 PM
AHHH! Thanks hadnt even thought about that making more of them work!
Old 12-08-2020, 05:45 PM
just got this one (102/122) thanks again for the advice!
Old 12-11-2020, 09:37 PM
Default Couple Uh Oh's
well I've made a couple mistakes. One is minor, the tower just showed up and the seller didnt show the bad parts which is expanded rust in the batt box mounting tabs. Everything else looks pretty good. I can fill or use the ammeter hole someone put in it. I can air chisel the rust-expanded tabs apart, clean, and fix them.
The other uh oh, is my 5.70x8 tires/rims showed up. I was surprised how tall they are. Assumed the 5.70 meant width and the height would be pretty close to the 4.80's. Apparently not!
4.80x8 16.1" diameter
16x6.50x8 optional wide fronts 16" diameter
what i bought - 5.70x8 18.1" diameter
All may not be lost. I am making custom HD spindles anyway hence the 5-bolt front wheels. So the spindles can be welded on 1" higher. Need to check the swing of the tires, may have to move them outward a bit to get the same steering circle..
Anyone fixed those "expanded rust" tower tabs, and anyone messed with 5.70's on the front?
Old 12-11-2020, 09:57 PM
Wow that was fast. After typing about an air chisel, I remembered that I have cold chisels so I went into the shop and decided to just see what could be done. Chiselled the rust right out and the spot welds still holding. I can treat with rust converter, paint, hammer back together and call it good! The last pic shows one hammered closed again...
Old 12-11-2020, 10:30 PM
well, ya got one thing solved.
The replacement dash had an ammeter drilled into it too? Wow must have been a high need for ammeters in your area.
As for tires, I have absolutely no clue because none of my tractors run new tires. I mean I'm sure you could still make those tall ones work, IIRC the narrow tires that would come stock on the smaller Cubs (O, 70, 71, etc) were a little taller than the wider ones.
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
