#21
You're probably right, never thought of that.
Old Cubs and Cub parts are about non existent in western Canada and about one per thousand square miles in my area and I have that one. But I'll be keeping my eyes open for a good cast iron pan. I do have a bunch of PTO and rear lift parts to trade. |
#22
also CT i think theres a guy that has tons of cub stuff.. i would replace. you know it will be in the back of your head all the time you riding it. heres a few of them. no clue on how they are with shipping. i havent bought anything from them.. they r all fakebook. so i guess board doesnt allow them. but just use numbers off the end . https://******************/marketpla...52507821672110 https://******************/marketpla...87118604839268 https://******************/marketpla...76454466024896 https://******************/marketpla...22175882453446 |
#23
Thanks ICOM. Cast pans with the dipper extension seem rare.
#24
no idea on how rare the deep dish pan is but here is another guy and he will ship.
i have 4 motors 10 to 14 and there all deep dish. so again no idea .. something tells me this guy might have one face book. com/marketplace/item/4033520333325402 |
#25
It all started with a little 122...... |
#26
Thanks for the info Westerncannonball. I have friends that have Washington postal boxes.
I got everything run through the parts washer this morning and on closer inspection, I believe Darkminion had it right with the crank bearings. One is very raw! Good news is my old work place had two new old stock bearings for free. I milled .008" off the head before it had nice crisp edges right to the combustion chamber, more than I thought it would need. I ground the valves and since they had been changed in recent history they cleaned up pretty quick. The black line, in the one pic, is the wear area after taking a couple thou off. I also noticed that the top of the tappet adjustment was wore in from the end of valve stem. So I ground that ridge off too. That would give you a false feeler gauge reading when setting the valve clearance. Turned out to be about .003". I dropped the block off and ordered a piston today. |
#27
Still waiting on a piston to arrive, but it's snowing now, so the sled dogs should get through a bit faster.
Until I can find a reasonably priced cast iron oil pan, I'm going to use this one. I cut studs from grade eight threaded rod. The threads in the pan are wallowed a bit in the top third, so I installed the studs with two part, metalized epoxy. The studs are threaded right to the bottom to ensure 100% thread use. The front stud length is fairly critical so they don't hit the axle in full articulation, but pretty easy to check without the motor attached to the pan. |
#28
When re-installing, getting the motor and driveshaft aligned and coupled up usually requires a bit of sliding and maneuvering of the motor.
I hope the permanent studs do not complicate that for you. |
#29
^^^ Shouldn't be a problem? Same amount of wiggle room as with bolts.
Do you normally loosen the pan bolts whenever removing and reinstalling the driveline? |
#30
Yes you do, but you can always install the driveshaft from the rear.
You can strip out a nut easier than a bolt that is why they use bolts in the pan, hopefully you can find a pan...
Up to 534 and counting... I give up updating my profile! |
