Old 03-07-2021, 10:46 AM
WesternCannonball's Avatar
WesternCannonball WesternCannonball is offline
Originally Posted by Cubcadet_107 View Post
Then pulled the rear cover. Unbelievably, I did not find what we all expected. There was not a single spot of rust inside this transmission! And the fluid was most definitely old Hy-Tran. By the color of it, I would say it might be OEM fluid that the tractor came with from the factory
Once completely drained and cleaned out, it looked pretty good.
Under the top cover everything looks in good working order. Shifter forks aren't bent out or anything, and the gears shift properly.
So, after putting the rear cover back on I filled it with new fluid, SAE 30 oil as the manual states should be used if not using Hy-Tran. Poured it in through the top so that I could coat all the gears with it. Then put that cover back on, and bolted my fender pan back to the tractor. Tomorrow I'll go for the test drive.
Boy, you got lucky! Mine had water mixed in. After cleaning the rust off the bottom of the case and the top of the gears that were exposed, I poured 6 qts of oil in and it wasn't enough. How much did yours take in all?
It all started with a little 122......
Old 03-07-2021, 11:08 AM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
I would assume you meant 6 pints of oil? 6 quarts is almost the capacity of a hydrostatic.
I bought a 5 quart bottle of SAE 30 oil, and there's probably 4 quarts (8 pints) of it inside the transmission currently. Unfortunately I spilled a bit from the fill hole, which was when it told me I should stop
Then, I took it on my very (VERY) comprehensive test drive. Soon enough I bet I'll be taking these Cubs all the way down to the end of the road (3 miles!) for a test drive...
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 03-10-2021, 10:48 PM
No, 6 quarts of 30 weight oil poured into the rear end of a stickshift via the shift cover. It came up to about a third of the way up the lowest gear. That was enough to get the thing rolling freely and push it back into the frame for reattachement.
Old 03-11-2021, 02:35 AM
Bryan S Bryan S is offline
Well, I do know that the Hydro on the 2182 holds about 7 quarts so
I opened up my Model 70/100 Operator's Manual
to page 21 "Lubrication" and it says the Transmission capacity
is about 7 Pints, 6 quarts is a bit much.
I also found this here. HTH https://www.onlycubcadets.net/forum/...ead.php?t=4673
The Cub Pack. 70, 100 (creeper), 104, 122 (2), 1250, 1810, 1863, 2182, LTX 1050, SLTX 1050, SLT 1550, SLT 1554, Snow Chuckers 450, 451, 826T, 1030E, 2 plow blades. always looking for "just one more"
Old 03-11-2021, 10:00 AM
You fill the case with oil up to the plug on the rear cover.
Up to 534 and counting...
