Old 12-31-2021, 09:45 AM
Getter-Done's Avatar
Getter-Done Getter-Done is offline
Leave plenty of room for your boot clad feet in the winter!!
True, Very True
Old 12-31-2021, 07:52 PM
Here's the catch up pictures
I cut the flanges off the bucket,
And ground it smooth.
This is the bucket in post #5
I welded the grooves in later.
Had to add plates to level the mounting surface
on the back of bucket.
The arms are a few inches inboard.
Drilled holes and added DOM tube for
mounting a brace across the top of the vertical arms
Old 12-31-2021, 08:02 PM
Squaring and welding vertical post
Used the bucket for work bench
Boring holes for insert bushings for top pin.
Old 12-31-2021, 08:08 PM
More vertical arm work.
Old 12-31-2021, 08:19 PM
brackets for top pin
Drilled hole in brackets and tube
For locating top bracket before final welding
of brackets when Top pins are installed.
The pins are supposed to be here this week.
Used DOM tube again to keep from crushing the tube,
when I tighten the bolt.
Old 12-31-2021, 08:26 PM
Just a few more pictures of the DOM tube,
I used on the vertical post.
I will make caps for the posts.
Here it is ready to weld the DOM tube in and grind it smooth.
Old 01-01-2022, 08:54 PM
1811woody's Avatar
Default Nice work
Im also interested to read about your 1863 and a half did you post your progress for that build?
Old 01-02-2022, 08:59 AM
Glad you brought that up
In post #14 (this build) graduated to a 1864.
I was going to put the power steering and everything involved on the 1863,
That's where the 63 & 1/2 came in.
Now it will be a 1864 since I purchased that one.
I am making (Two) of all the smaller pieces of loader stuff
In plans to make the 1863 another light duty loader.
At-least that the plan for now.
Old 01-11-2022, 12:01 AM
The Hyd. controls showed up today.
I have a few pictures before this
I will catch that up
Here is the Joy Stick 1st
Then the Add On's
I may Stack them ??
Old 01-11-2022, 09:34 AM
Ambush Ambush is offline
You are gett'en 'er done, nice work! Handy to have some commercial machinery at your disposal.
I'm curious about why your joystick control only has two work ports. The purpose of a joystick control is to have four work ports controlled by a single lever.
