Old 08-12-2021, 04:26 PM
MattN124's Avatar
MattN124 MattN124 is offline
For the front hubs, I'm still looking for used parts.
My set is good, but I still need a set for my "original" machine. Cannot find new ones anywhere.
I'm also going to local machine shops to see how much it would cost to have a set fabricated.
Here is what my rotor/hub assembly measures at:
  • The overall rotor diameter is 7.75"
  • Rotor thickness is about 0.135"
  • Hub flange is 4" square and 1/4" thick
  • Distance from the face of the rotor to the rear face of the hub flange is about 4.0344" in length
  • ID where the bearing are is right at 1" (spindle thickness just under 1")
Old 11-14-2021, 12:38 PM
allyolds68 allyolds68 is offline
Originally Posted by MattN124 View Post
Would you mind if I posted those pictures here? That way anyone else who is looking later will have them?.
I don’t check in here too often…
Yes sure… post away
FWIW the new front calipers work great. I wouldn’t spent five minutes on those original Tol-o-matic calipers. They are just junk. I still have my back ones but as soon as they start grinding again I’m going to tweak a cheap set of chinesium calipers for those too.
