Old 08-29-2010, 09:06 PM
Sminkey
Guest
Posts: n/a
Default Welcome to the club!!
Very nice way to start off some "yellow fever". You're 123 looks to be in very nice shape and good luck figuring out the knocking noise!!!
Old 09-05-2010, 05:07 PM
T-MAN T-MAN is offline
Default Viewed your video.
Viewed your vid. when l got mine, l noticed it had a knock of some type. l was worried that it was in the engine, turns out, it was the pto. clutch.
Try this, w/ the engine on idle, carefully remove the dip stick, if the knock gets louder, it is probably a rod or wrist pin, or a piston slap. you can also remove some of the engine oil, look for metal particles, if none are seen, fill the level back w/ Lucas Oil Treatment, if the sound gets quieter, you most likely need to tear the engine down and address the issue.
just remember, the hard parts (block, crank, cam, head) are hard to come by, and are awfully expensive. if the engine is not allowed to blow, you can avert this expense.
Best wishes.
Tags
newbie 123 georgia
