Old 02-11-2022, 07:52 PM
athomas's Avatar
athomas athomas is offline
Originally Posted by West Valley G View Post
Yes that is correct. Take the .002 undersize crank and grind it .010
under and buy another rod to fit that. No problem, clear as mud on this
end . Have been buying parts from the guy that you linked. Been just
fine so far.
Ken
remember .010 under from the factory spec not .010 plus the .002 it is already under size, finished journal should end up 1.490 plus or minus .0005 like george says best to take the new rod to the shop with the crank unless you got a good set of mics at home and are good with them !
Old 02-21-2022, 09:11 AM
mortten mortten is offline
The guy I use won’t even turn a Kohler crank without the rod in hand. We said they are way off on their specs.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
