Old 05-08-2022, 09:57 AM
Normally the "deck" on those engines are pretty flat, it is the heads that need attention.
Old 05-08-2022, 11:11 AM
RoseHillFarmIHCC125 RoseHillFarmIHCC125 is offline
Good to know. I have a piece of old granite counter top that I’ll use to refinish my cylinder head.
Old 05-10-2022, 10:15 PM
RustyShackleford's Avatar
RustyShackleford RustyShackleford is offline
3M makes some sandpaper sheets with a rubbery sort of backing that works great for surfacing the head. Little brushing off Prussian blue on the bottom of the head will help a lot in identifying where the low spots still are, too.
Old 05-12-2022, 02:08 PM
DSarow DSarow is offline
Another tool in a guys arsenal is a thread restorer kit. It is different from a tap. It reforms the thread without taking out a bunch of metal. Taps are for making threads in a hole that has been drilled for the proper size. A restore kit has dies also to massage external threads. If you're unsure of a bolt or nut on your Cub, grab your kit. It also comes with thread files, little bit on a shaft or bolt some times all you need.
Old 05-12-2022, 03:07 PM
I failed to add JAWCO as the brand of restore tools I use, good prices, you can also order singles, etc.
Old 05-13-2022, 08:33 AM
X2 on this tool in the shop. Every hole, bolt and nut gets cleaned up
before it goes back together. Makes reassembly a whole lot easier. And
besides it's kinda fun,
Ken
