Old 07-08-2022, 03:50 PM
Farmall450's Avatar
Old 07-08-2022, 11:36 PM
Once the magnet is broken you have 2 magnets as stated.
best to replace the broken magnet with a good used one, or you will reduce the charge output.
I'm thinking there are good magnets sitting around in junk KT17 flywheels in someone's pile of parts.
Old 07-09-2022, 06:02 AM
Thanks Farmall & George.
I'll have to look around and see what is available around here.
Old 07-09-2022, 11:57 AM
Farmall450's Avatar
Otherwise there are some on feebay:
https://www.ebay.com/sch/i.html?_fro...Desc=0&_sop=15
Old 07-11-2022, 07:28 AM
Red so i believe North
OK, I looked at that eBay Ad. Dimension wise, it is the same as mine. The seller states it has red markings, while mine have blue. Is that significant or maybe just a "vendors" markings ?? Doesn't each magnet have a N & S pole to it ??
Old 07-11-2022, 11:02 AM
Farmall450's Avatar
Yes, perhaps they could be different mass/strength but what are the odds of that
Old 07-11-2022, 01:54 PM
I am going to pull the trigger on that Ad.
Old 07-12-2022, 01:10 PM
I need some insight and clarification on these Flywheel Magnets. I re-watched the "Taryl" video again, focusing in on magnet polarity. He shows taking a magnet and going to the edge of each magnet to determine if the Flywheel Magnets attract or repel. I am NOT finding that to be true in my testing. As I mentioned earlier, I have one broken magnet out of the six. The five remaining magnets test this way. Taking a telescoping magnet, if you place that magnet in the middle of the arc, three attract, and two repel. If I go to either of the ends, they all attract.
So, I see on eBay, a person selling a Kohler Flywheel Magnet. He states, it is a "N Pole" Magnet. Is the N Pole magnet type, attract or repel ???
Old 07-12-2022, 06:34 PM
RLause's Avatar
RLause RLause is offline
Here is a link to some very good information on replacing the magnets.
https://www.wheelhorseforum.com/topi...nets-came-off/
Richard
Old 07-12-2022, 06:43 PM
Thanks Richard.
