Old 10-02-2022, 08:30 AM
FWIW:
The the fuel shutoff solenoid does multiple things beside helping to eliminate soiling yer britches when it backfires.
The EPA had a hand in it to prevent raw fuel from entering the combustion chamber, adding about as much pollution as a flea fart.
Also it tends to prevent "dieseling" which is the engine continuing to run-on, after the spark is stopped because the combustion chamber is hot enough to cause ignition (usually called preignition)
So now you know all the reasons for it.
Its a good device when it works
Old 10-02-2022, 12:32 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
I guess I have been fortunate with all of my older machines. None of them have ever backfired after a shutdown. Of course, I idle all of them down for a brief period before shutting them down. It's a short cool down. It's the little things like this that make the difference. Also, I engage the electric PTO's at a low engine speed, then place the engine to full throttle to mow.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 10-02-2022, 12:40 PM
Me too, no issues.
Old 10-02-2022, 09:53 PM
Wild Bill's Avatar
Wild Bill Wild Bill is offline
I worked the 1712/1812 for about 3 hours today. It didn't have a hiccup at all.
I do need to back the idle screw out, just a touch though.
Tomorrow, I'll run it for a few minutes, then do another oil change. Then it will be ready for normal duty.
Original OCC Super Mod....and former OCC Co-Admin.
I was hacked........
Old 10-02-2022, 09:55 PM
Wild Bill's Avatar
FWIW:
Interesting stuff!
I'm thinking this one is gunked up, from sitting for 3 years or so.
Old 10-03-2022, 06:40 AM
As you know, I have a 782. I have run both the Kohler and Walbro adjustable Carbs. Although the Walbro adjustable is better than the Walbro fixed jet, I'll take a Kohler (Carter) any day.
Old 10-03-2022, 04:25 PM
Farmall450's Avatar
FWIW:
It has a place, but it also adds a new failure point
Beats a manual shutoff for accessibility, though.
Old 10-03-2022, 09:03 PM
I don't think Carter ever made a bad design Carb!
From a little 2 hp Briggs, to the larger 4 barrel carbs on cars/trucks.
Simple and effective.
I've been around them since the 50's
Old 10-03-2022, 11:09 PM
Wild Bill's Avatar
I worked the 'ol girl for about 1.5hrs tonight. Brought her inside and gave her a compressed air bath. Then did a oil and filter change......the second one in less than 5hrs of use.
I changed the oil and filter before I started it the first time Saturday. And it was already very black, so it might take a few changes, to get the M18 cleaned out.
