Old 12-08-2022, 07:22 AM
farmer52 farmer52 is offline
Originally Posted by hugo454 View Post
I have 2 that I am "saving".Both were local Craigslist finds. One is a 1440 and the other is a 1782. After much consideration I have decided to replace both engines (they are both n/g), with 22hp Predator engines also called the "670".
Isn't the 1782 a Kubota Diesel?
Ken
Old fart - new to Cub Cadets
Looking for a nice original low hour 1772 or 1782
Old 12-10-2022, 06:36 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Wink
I replaced the destroyed dash with a nice original.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 12-13-2022, 09:12 PM
1711Cub's Avatar
Thumbs up
Found an excellent tunnel cover.
Old 01-04-2023, 11:14 PM
1711Cub's Avatar
Smile
Replaced the worn and rusty seat base with a nice paint and hardware original
Old 01-05-2023, 06:51 AM
Nice! Do you ever sleep? I am jealous....how do you find these items?
Ken
Old 01-05-2023, 09:26 AM
1711Cub's Avatar
Thumbs up
I find the tractors on either FB Marketplace or Craigslist. Most have been from Marketplace.
As for parts, I have shopped at all of the major internet Cub parts retailers. The used stuff generally comes from Ebay.
Old 01-10-2023, 09:26 AM
1711Cub's Avatar
NOS deck lift lever cap
Old 01-10-2023, 01:39 PM
Farmall450's Avatar
Probably available on McMaster if you don't want to spring for OEM, or can't find it anymore.
Old 01-13-2023, 01:23 PM
1711Cub's Avatar
Lightbulb
Might have to try one of these.
https://www.lowes.com/pd/Hillman-1-i...B&gclsrc=aw.ds
McMaster-Carr:
https://www.mcmaster.com/hole-cover-...panel-plugs-8/
Old 04-15-2023, 10:44 PM
1711Cub's Avatar
Wink
I replaced the Hytran, filter, and the relief valves on this unit today. The fluid had moisture in it. The valves are rebuilt units from Machtech. All of this fixed the erratic function and leakage of the hydro.
