Old 11-29-2022, 06:48 AM
X2 on no loctite
Old 11-29-2022, 06:54 AM
Get some gasket paper from your local parts store and make a gasket for it.
Easy to do as you already have the pattern right in front of you.
Old 11-29-2022, 11:50 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
Originally Posted by Redneck #1 View Post
The bolts appeared to have a Lok-tite substance on them. Is that something you would recommend?
I've seen that on my stuff too. Don't believe it was Locktite. Probably a thread sealant. I've never replaced it on the bolts, and don't have a leak because of it.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 11-29-2022, 12:28 PM
Charlie has the cover gasket.
https://ccspecialties.org/clutch_driveline_rearend.html
Old 12-14-2022, 02:44 PM
Redneck #1 Redneck #1 is offline
I put on a new filter, new gasket, and Hytran fluid. Works great now. I appreciate all the suggestions and coaching on this project. Thanks
Old 12-14-2022, 03:54 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default Hydro Fluid
Redneck#1, What did you use to get the gasket off rear end? Super clean.
Thanks and have a great day.
Bob
Old 12-14-2022, 05:46 PM
Used carb cleaner and a small stainless steel wire brush from Harbor Freight. Scraped a little with a plastic scraper and carefully on some spots with a utility knife.
Old 12-15-2022, 06:51 AM
Club Cadet Club Cadet is offline
Are you sure the pump is turning?
Make sure you have not lost or sheared a pin in the driveline.
Yeah are you sure the hydro input shaft is turning?
<edit> I guess I should have read to the end of the post before I chimed in LOL. I knew it was a fluid issue.
